RE: U-Can-Do 3d 46?
sdcranford... It should work on that prop... The (wide model) works great on the
APC 12.25x3.75... You should give that prop a try....
I think another "Do" is on the way.... More about it later... I cleaned up the saito
all looks good except for a small dent in the intake pipe.. Tried to order one but
they are on back order til 01/06... So I'll use it for now.. It's not that bad, just
looks... well.... I still have not really turned the crankshalf... I'm not sure if the
hole on the push rod cam cover let some dirt in there?? I think it's a vent hole?
Anyway I wanted to look into that a bit more.. I have the rec. and servo boxed
ready for a check up at Hitec.... And the sad part the "Do" is in the can...
That did not sound right:-)
