RCU Forums - View Single Post - V-Tail FlatBat wobbles!
Old 11-14-2002 | 12:54 PM
BalsaBum
Default V-Tail FlatBat wobbles!
The wobble in the yaw axis seems to get worse with an increase in airspeed with throttle open. You make an interesting point, I'll try a high speed dive with throttle off to see if prop vorticees are at work here. The wing, although swept, is flat bottom and I may be trying to push it thru the air to fast.. I'm still experimenting. Thanks for the reply. BalsaBum
