RE: Insight build...another wood roach.
What started out as a simple little morph canopy job turned into what looks like an explosion of the foam factory. Holy moly this stuff gets everywhere and sticks to everything. I would take a picture of the mess but it just too darn embarassing.
The canopy if off an Aries with needed to be much retired. So.. i cut out foam blocks and started cutting angles and what not till i got the angles, height, shape i thought i was looking for and then started sanding and sanding and shaping. In actual fact, it went really smoothly. Someone with a little more builders skill and it would be a piece of cake.
Here a the results of the Bud Light intervention.
note the blue from the canopy will be removed and blended to the new colors of the plane.
