RE: BVM F-4 Owners
Craig, Thanks for the great info. That seems to be a good way to mount those Wing tanks. I will try that. I guess you could do them the conventional way to where you mount them through the aluminum tubes inside the wing tanks right? Do you use a TITAN for yours? I will be using one for mine.
Phil, Do the chutes some complete with spring loaded hardware to deploy the chute? If so I would like to buy one. Tell me where to send the money or do you want C.C? I will post some pictures here shortly. Thanks guys! -Patrick
