ORIGINAL: bvmflier
Craig, Thanks for the great info. That seems to be a good way to mount those Wing tanks. I will try that. I guess you could do them the conventional way to where you mount them through the aluminum tubes inside the wing tanks right? Do you use a TITAN for yours? I will be using one for mine. -Patrick
Patrick, Yes, you can mount the wing tanks through an aluminum tube but I have found that method leaves the tanks a little wobbly. My brass tubes run all the way through the tank and are glued top and bottom for more rigidity. Either way works.
I have a Netherlands Pegasus HP in my F-4 which gives me great vertical. The Titan will do likewise and is an excellent match.
Hope to see you at FL Jets.....Craig
