RE: Help for a wannabe and son
Glow plug wrench of some sort.
Whatever you need to install/remove the wing(s).
Chicken Stick and/or Electric Starter
Glow Plug Heater
Fuel and a pump of some sort.
Battery to run starter and if you have one your electric fuel pump.
Voltage Meter for testing your batteries under a load.
Small pair of needle nose pliers
Small screwdriver phillips and standard
Some sort of cleaner and paper towels (I use 409, works fine)
For repairs
15 or 20 minute epoxy
Thin and Medium CA and perhaps some accelerator (I use it all the time with great results)
Monokote Iron
Exacto Knife and plenty of sharp blades.
Straight edge for cutting covering
