RCU Forums - View Single Post - Official Mayhem Thread
Old 12-11-2005 | 01:19 PM
  #866
Rockman's Avatar
Rockman
Default RE: Official Mayhem Thread
Okay, the difference in the RTR and Pro chassis is important if you want to use a starter box. The RTR flywheel opening is smaller so if you want to use a starter box you must dremel out some of the opening and put a 45 degree angle so it won't rub the starter wheel. Also the Pro version has milled recess areas that save weight. Other than those two minor items there is not much difference.
Rockman
