RE: RichModels Works LTC ARF's
[quote]ORIGINAL: vt325xi
Have you flown your Quickie yet?
I crashed mine on the first flight. I had a .52 4 stroke and it took off but took a long takeoff roll. Then I couldn't get it to turn or stay at altitude. I had full back stick and it barely climbed.
What control throws have you set up? I think it ran out of throw on the canard, and yes I had it set where down is climb on the canard.
Any thoughts would be great as I'm about to order another Quickie.
[quote]
Have not finished assembling mine at this time. 4" of snow out there and I am not much into winter flying. I will try an get set up info from ARF maker. He had these on ebarf.
I will set this up on my Futaba 9CA with high rate being all I can get low about 60-70% of high with 20-25% expo. CG I may move back,
If you did not climb well then:
1) CG was forward
2) incidence on canard (fore wing) was wrong
3) too much down thrust
turning you may have to cordinate rudder with aileron input.
bob
