RCU Forums - View Single Post - Dynaflite SE5A / S.E. 5A / SE-5 / SE-5A / Build
Old 12-11-2005 | 04:28 PM
Prop Nut's Avatar
Prop Nut
Default RE: Dynaflite SE5A / S.E. 5A / SE-5 / SE-5A / Build
Hi Dean,
I do fly mine with a 1.20 but it is WAY over powered (its just what I happened to have handy when the ASP80 I had purchased for it turned out to be a bad engine), I have seen them fly on OS70's and very well. I am very sure based on the other .91's that I have, that the SE5 will fly fantastic with the .91.
What I did to the tail was pretty simple, I reduced the angle of the tail skid so it could skip (or slide) over the ground instead of catching, the stock configuration is almost at a right angle to the ground resulting it the rudder catching and the hinges being pulled out.
ID:	368343   Click image for larger version
ID:	368344   Click image for larger version
