RCU Forums - View Single Post - Dynaflite SE5A / S.E. 5A / SE-5 / SE-5A / Build
Old 12-13-2005 | 08:31 AM
  #36
jstanton's Avatar
jstanton
My Feedback: (14)
Default RE: Dynaflite SE5A / S.E. 5A / SE-5 / SE-5A / Build
PfalzPflyer
Take your time and make sure you understand each step before you glue anything together. I to only used two servo's for the ailerons and connected the together like PropNut suggested. I have 2-56 rods using higher torque servos for the ailerons. My servo's in the wings are GWS SO3-BB servo's that are rated at 89OZ torque at 6 volts. I am also using a 1800 mah 6 volt battery to power the servo's. Beef up the tail skid section and glue tooth picks into each hinge in the rudder. You'll love this plane. I have talked to many people using engines from a 91 4 stroke to a 120 4 stroke and everyone just loves the way it flys. I bit a small gasser would even fly thing plane well, maybe a 25cc with electronic ignition. What do you think PropNut?
PropNut
Looks like you have a great looking WW1 airforec going there. I to am looking into the Albatross from Fun Aero, but I will wait to see what Santa brings.
