Evolution 46
It seems like more and more models of the Evolution engine are showing up in the ads these days with sizes ranging from 40 on up, maybe even to a 61. It looked to me like one of the smaller ones was a bushing engine and cheaper priced, while the NT series were ball bearing engines.
More than likely the 3 bladed prop will give beginners a bit more ground clearance. The engine should spool up quicker without the flywheel but not idle quite as slowly. A 2 bladed APC will add some weight without needing the flywheel.... maybe a good compromise.
Ernie
