RCU Forums - View Single Post - Aeron advice needed
Old 11-24-2002 | 07:53 PM
Tuomo
Default Aeron advice needed
Hi, just to let you know, this is what I am doing. I built the servos in wing as per plans, but -- this is the news -- I am building another mounts in tail. The extra weight is very small.
If it balances ok with the Ys in front, I will place servos in wing as you advised. If it looks like I will need tail weight, I will cut out the tail mounts and move 1-2 servos in tail.
Time will tell what is best. This far the only real modification is omitting the pull-pull servo linkages. I have some nice carbon rods that I want to try out.
