RCU Forums - View Single Post - E-Starter prop and power question
Old 12-13-2005 | 08:24 PM
pox67
Default RE: E-Starter prop and power question
Thanks AJ1202, that is all the info I was looking for
I'll grab a smaller few smaller props next time I am up at the store.
I figure if I keep the throttle under 2/3s that will be equivalent to a 2s battery. If the Spektrum DX6 doesn't have a throttle rate change I'll just tape off the top portion of the range on the TX.
I'll go brushless when I burn out this motor. I don't want to go the custom route yet as this is my first plane so want the stock setup as much as possible to eliminate building errors.
The CC Sprite-25 ESC is going back to the store and I'll pick up the cheapest Li-Po compatible ESC they that can take about 10A.
I haven't heard anything about this "water break in", I think you better explain before I douse the motor in the sink!
Thanks for the info.
