RCU Forums - View Single Post - Weston Pipes
Thread: Weston Pipes
Old 11-16-2002 | 05:17 PM
DennisF
Default Weston Pipes
Hi
Guys read the thread on the pipes loosing the pressure tap,
Guys all you have to do is drop me an e-mail or give me a call anytime i am at your service as my company imports the pipes.
The most common reason the tap pulls out is the pressure line is left to whip around in the exhaust stream, this causes the line to work on the fitting and eventually pull it out as the aluminum is very thin walled.
The worst thing you can do is to try and repair it with JB weld, what happens is the solvent from the adhesive wicks into the pores of the aluminum and resides there then if you take it the pipe to a welding shop after you have applied the JB weld the welder strikes an arc and the solvent lights off this produces to great a heat and the aluminum melts away end of pipe.
Just secure the pressure line around the pipe with a tie strap and as is well, should you need to get the pipe repaired Weston is very good about this and if the pipe has not received JB weld they will fix it for you for free just pay the shipping cost hope this covers it.
Dennis
JDEnterprise's
