RE: E-FLIGHT BLADE CP
I should have mentioned I fixed the collective popping which was caused by the servo connectors where it met the swash ball. I pinched them with pliers while on the balls. I also trimmed and set the pitch with a pitch gage while setting the TX in idol up. That is unplug both motors from the 4 in 1 and setting the pitch at up +10, 0 middle throttle and -10 low throttle.
