RCU Forums - View Single Post - How big of a warbird can G26 handle for scale and mild acro?
Old 12-14-2005 | 02:45 AM
Antique's Avatar
Antique
Default RE: How big of a warbird can G26 handle for scale and mild acro?
Connect a spring scale to the tail wheel, hold the scale with one hand, open the throttle, see how many pounds of thrust the engine will pull....Have a helper handy in case your grip slips on the scale..
A normal G26 will pull 17 lbs at 9000 rpm with a Mejzlik 18-6 if the muffler is not too restrictive...The stock muffler is.....Only 8200 rpm....
