RCU Forums - View Single Post - Good First Planes
Old 12-14-2005 | 08:25 AM
aeajr's Avatar
aeajr
Default RE: Good First Planes
SPACE
How much space do you have for flying? If you have totally clear space of at
least 600'X600', about 9 square acres, approx 4-6 6 square football/soccer
fields,
then I
can recommend one class of plane. Call this class 1 - CL1
If your space is more like 200X200 (one square acre) then a different plane is
in order. Call this class 2 - CL2
If it is less than that, different again. This we will call this class 3 -
CL3
These are my own designations and are based on my subjective ranking of the
space a new flyer should have when learning on his own. An experienced flyer
can fly faster planes in smaller spaces, but a new flyer wants to have more
space so you are not in a constant state of panic trying to turn. Now, you
can get above the edges of the field and expand your space, but if you lose
control, you drop in woods, on top of kids or smash someone's
windshield. If that windshield is in a car is traveling down a road when you
hit the windshield, you could cause an accident or worse.
So much for space. You get the idea.
I don't recommend pretty planes as first planes. They are too easy to break,
too hard to fix and look bad in short order. So you won't see any especially
pretty or true scale planes. Make one of those your second or third plane. I
also don't recommend two channel R/T electrics, so you won't find any on the
list. If you want one of these, I would suggest the Firebird series from
HobbyZone. They can be very easy to fly and can be a lot of fun, but they can
also be very easy to lose. You should plan to fly them in dead calm air when
you are first starting.
I feel a high wing three channel R/E/T plane is your best choice for a first
plane. R/E/T will require a little more learning than the two channel R/E
planes but is a better choice as a first plane, in my opinion. These use the
same control inputs as more advanced planes and can be flown in more wind once
you have mastered them in calm conditions.
