RCU Forums - View Single Post - Dynaflite SE5A / S.E. 5A / SE-5 / SE-5A / Build
Old 12-14-2005 | 08:41 AM
  #38
jstanton's Avatar
jstanton
My Feedback: (14)
Default RE: Dynaflite SE5A / S.E. 5A / SE-5 / SE-5A / Build
David
Thanks for the input on the FunAero Albatross. I'll save my money and get a Balsa USA WW1 kit after I build the Flair Fokker D-VII. I will be building a WW1 Airforce. I of like the 1/4 scale Sopwith Pup and Fokker D-VIII from Balsa USA. I will be putting gasser in them.
I think you are right about this Dynaflite SE-5a Mine weighs in at 10lbs and with the 1440 sq. in. wing area she flys great on a Magnum or Saito 91 using a APC 14x6 prop. I was thinking a Ryboi 31cc with electronic ignition might be a good gasser, but this my be adding to much weight. That would bring the told weight up to 13.5 lbs are so.
Have a great christmas. I hope you all get what you all want.
