RCU Forums - View Single Post - CG problem
Thread: CG problem
Old 11-16-2002 | 02:06 AM
gfinan
Default CG problem
Easymoney,
If I remember right 1/2 kg is equal to about 1.1 pounds. This amount does sound excessive for a Tiger 40. Double check that you are balancing the plane at the right CG. If it is right however, you will have to add whatever weight it requires. As stated above, the further forward that you can get the weight the less it will take.
Greg
