RCU Forums - View Single Post - Lathe
Thread: Lathe
Old 12-15-2005 | 12:13 AM
av8tor1977's Avatar
av8tor1977
Default RE: Lathe
How much would you charge me to make a spacer with the crank taper like the one in my picture on the right?? I'm converting another Kioritz 23.6cc, and was working on it tonight. Turns out the flywheel is one of those laminated steel jobs molded with plastic. Can't use my trick for this one! I could post a drawing with measurements. I don't even have my new lathe set up yet, much less have the ability to do a taper, and I need this motor pretty quick. What do you think?
AV8TOR
