RE: will it work?
10.25 lbs --with the CF pipe -10 flat - it is a terrific pattern plane -except the pattern die hards may poo poo it
Just set it up with reduced throws JR9411 servos on 6 v so you get best resolution on servo setups
Mine was very stable but you can not fly it accurately wide open -you need to use a throttled back approach and just feed in power as needed.
