RCU Forums - View Single Post - New Composite-ARF Extra 260 Schemes
Old 12-16-2005 | 07:38 AM
Dean Bird's Avatar
Dean Bird
My Feedback: (39)
Default RE: New Composite-ARF Extra 260 Schemes
I'm very interested to hear any flight reports from Frazer.
There is a a thread in the "Giant" forum from a guy that just took delivery of his new 260 with one of the original schemes.
http://www.rcuniverse.com/forum/m_3654062/tm.htm
The comments in that thread are impressive.
"This wing weighs NOTHING, and is very tough aerodynamically."
"The amount of prefab is really cool, control arms are in the surfaces, hatch is completely done with screws and all (minus canopy). All the internal parts are literally sand, snap, and glue together."
"By the way, the fuselage weighs NOTHING! It has to be less than 3 pounds, and its HUGE."
"As far as the plane, I cannot say enough of how much thought and engineering went into this plane. They might be expensive, but so much work is done for you, that you do truely only assemble it. The stabs have even already been fitted, drilled, countersunk, tapped and had blind nuts epoxied in the stab tube, as is the canopy frame, while all control arms are already in place. Pretty slick!"
"The composite work is top notch, as always. I am curious to how much the bare fuse weighs. I would guess 2lbs tops. Everything seemed to be terminated properly, filets were done properly with a nice constant radius (not that that helps anything, it just shows the pride of the person making it) and the carbon tow looks like it has been wet out properly."
I'm really looking forward to getting this one!!!!!!!!!!!
Take care,
Dean Bird
Sun Valley Fliers
Phoenix, AZ
