RE: E-Flight Ultimate FX foam bipe!
Thanks for the input. That stinks about having to make the mods. That's part of the delima to buying ARF's.
Here's a little tip on horns - throw the little keepers away and use a Z bend in the wire to attach to the horn. Use a Dubro micro pushrod keeper at the servo arm. The 1/16" ply horns are too thick to work with the keepers generally, besides being "microscopic" for those of us with huge hands they are hard to work with. But it sounds as if you made things work which is what matters.
Good luck and let us know how things work out with the li'l bird and how she flies.
