RE: Estarter Build Help
I HAVE NEVER HAD A STICK COME LOOSE IN FLIGHT. ON ROUGH LANDINGS YES , BUT THE NICE THING IS YOU JUST REGLUE IT . ANOTHER BONUS TO USING HOT GLUE IS , IF YOU HAVE A 12V TO 110 VOLT CONVERTOR , JUST PLUG INTO CAR LIGHTER AND PLUG THE GLUE GUN IN , MAKE SURE ITS LOW TEMP AND A MINI GUN, DRAWS LESS WATTS. WITH THIS SET UP YOU CAN DO QUICK FIELD REPAIRS . EPOXY WORKS BUT IT IS PERMAMENT , HOT GLUE YOU CAN SEPERATE IF NEEDED. HOT GLUE WORKS GOOD FOR MOST BUILDS I USE IT FOR EVERYTHING EXCEPT FUSALAGE ASSY.
