RCU Forums - View Single Post - Help with ARF build....
Old 12-17-2005 | 12:02 AM
2slow2matter
Default RE: Help with ARF build....
Have you tried to turn the joiner spar around? There is no dihedral to those wings, so the joiner should fit in either way. You could sand down one half of the joiner so that the wing will line up--then epoxy it all up. Add some fiberglass to the center section and the wing will last as long as the rest of the plane!
