RCU Forums - View Single Post - Help with ARF build....
Old 12-17-2005 | 12:39 AM
agexpert
Default RE: Help with ARF build....
Thanks for all the quick help!!
I discovered that although there is a slight alignment problem, most of it is due to compression of the balsa on one wing -half, in the center on the LE (probably from shipping). That being said, there is a small, but perceptible alignment skew of approx 1/32". I can live with that, I think.
I intend to call H9 and see if they have any recommendations, and hopefully they will be nice enough to send me a new wing.
I HAVE ANOTHER QUESTION THOUGH!!
The manual calls for 3/8" dihedral, but to line things-up properly the way they are cut, I get over 1/2" of DH. How big a problem is THAT??
Should I just use as much epoxy as needed to achieve the prescribed DH?
um....medic!!
