RCU Forums - View Single Post - Retractable undercarridge instalation in a RTF
Old 12-17-2005 | 12:17 PM
BaldEagel's Avatar
BaldEagel
Default RE: Retractable undercarridge instalation in a RTF
I have now taken apart the finnished side to allow the removal of the pressure pipe and installation around the outside of the wheel well, much neater, I have also come across a problem with the leg installed because I bent the wheel axel on the wrong side of the coil I have moved the wheel approx 1/4" down into the well, I need that 1/4" for the whell to sit in so that the retract locks, new leg needed as I do not think I can re bend a piano wire leg through 180 deg's,may have a go just to see if its possible.
Mike
