RE: NEED TO BUY ENGINE AND I NEED HELP
I must add here that if you do get it all messed up by moving the Super Tiger spray bar and get frustrated....
You can remove the carb and there is an eyebrow slot in the middle of the spray bar on the bottom side. This slot must face down the barrel of the carb when the throttle is wide open. It should look directly at you if you have the carb off and you are looking back up the barrel with the throttle wide open.
Enjoy,
Jim
