RCU Forums - View Single Post - E-Starter prop and power question
Old 12-18-2005 | 11:54 AM
pox67
Default RE: E-Starter prop and power question
It is coming along nicely, can't wait for the radio to come in!
I was thinking about the battery plate as I had read a few posts about it coming out. Then when glueing it in I noticed that epoxy doesn't stick to the hatch plate plastic! Man that is just dumb...the epoxy peels right off it. I tested using a couple of the rubber bands going from the wing support struts on the fuselage, you can see what I mean from the pic. Seems to hold it in quite tightly, especially if I double over the rubber band. The supports are over epoxied in so shouldn't come lose either.
AJ1202, super long threads like the Shun Da Cub one drive me nuts as I can never find the info I want in them
