RCU Forums - View Single Post - On board power
Old 12-18-2005 | 06:36 PM
Bevo
Default RE: On board power
Expert and Hobbico also make on board voltmeter that plugs into an open channel on your receiver. They are about $15.00. These are nice because when you turn your plane on you can instantly see if your battery is in the green, yellow, or red area. After your done flying you can check the indicator again before you turn off.
Bevo
