RCU Forums - View Single Post - Basic blade CP questions
Old 12-18-2005 | 07:53 PM
wacdmc
Default Basic blade CP questions
I replaced my burned out original blade motor with the aerobatic upgrade motor. I believe the pinion gear is different on the aerobatic motor. Does the main shaft gear also have to be replaced to mesh properly with the aerobatic motor's pinion gear? It works and flies fine but seems to make a bit more noise and doesn't spin as freely. Thanks.
