RE: Glass Cloth over Silkspan?
N1EDM, the set-up you're looking at should be fine; whatever nozzle works best for your epoxy paint will spray nitrate. The dope is usually sprayed 1:1 with thinner. The trick is not to get it on too heavy as to collect under the fabric. Wear a mask!
