ORIGINAL: turbine guy
Can someone tell me how to get the driver to work?
I've already jumper the resistor ("not initialized " on start-up menu)
I got the usb plugged into the computer-it makes a tone when I plug it in- The Saturn program does not "see" the camera
Pretty sure it's a driver not being seen.
When I installed the ops software it did not automatically pick up the device driver and I had to do that manually afterwards to get it to work. Right click on My Computer > Properties > Hardware > Device Manager. Then, if you see any yellow question marks then you are going to have to manually install the device driver. I don't remember the exact steps but it isn't very hard and you can find more info here:
http://camerahacks.10.forumer.com/viewtopic.php?t=1969
The name of the device driver file that you want to install is libusb0.dll.
BTW, all but one of my cams were 3.62 versions which require the short and if your cam is now reporting as "not initialized" then you have successfully completed that step in the process.
FYI,
Gordon
