RE: covering cowl
I would also spray everything with hair spray yes hair spray all it is, is laquer then lightly sand re-spray and with a very fine grit sand again. it fills the grain and helps with the adhesion of the covering, plus helps to iron out the wrinkles you may get. Iknow it sounds wierd but it works.
