RE: TF Contender
Too cold, here, a with the Christmas season I am not getting much done. I have marked the holes for the
fuel lines through the fire wall after mounting the engine.
It sure looks like the center of the .61 FX is sitting pretty high. I am going to order the Sullivan 10 oz
Flextank and fuel filler valve today.
It just looks like from engine position that the spray bar is going to be somewhat higher than the center of the tank. What does yours look like?
Of course, the tank will be pressureized from the muffler, so maybe that will help.???? What tank are you going to use?
Also, when I glued the firewall in, it squared up with the fuse on the sides and the bottom. There seemed to be no offset for thrust, is that the way it is supposed to be?
Jim
AMA 821369
