RE: changing tyres
you can use a hot glue gun, which is not permenant, you can rip it off, and no if you use a thick lube, its not going to ruin your gears, it'll just annex the power differently, maybe a little more stress. If you have a ball diff, then you can just tighten it up a lot, and it will work fine, thats what im doing.
