ORIGINAL: AFFORDABLEPARTY
Good day Todd,
I would like to take the opportunity to thank you for all of your time and patience.
On another note, i was wondering if it was possible for you to post a graph-taken from an engine that is operating correctly.
This would serve as referrence guide for when we check the engine data in the future.
Well, Since I sent your engine back and did not dowload the data before sending it, I am just pulling data here from another ecu I have on hand. This chart looks fairly typical of a "Normal" run, meaning all systems are working correctly. I do notice from this file that the temps are a bit higher than normal (for a Merlin) on this run, most likely due to the TC being inserted too deep in the nozzle. But... Should give you a good idea what a normal run would look like.
Todd
