Hi from the UK
I have a Seagull Dual Ace which I bought a couple of weeks ago. It was bought on Monday and flying on Friday. I have fitted 2 TT GP42's (cheap plain bearing motors which are well used) and needed a touch on lead to balance the light engines. I balanced it 10mm back from the suggested 80-90mm at 100mm from the L.E. and she flies superbly. Very quick and highly aerobatic. I can prop-hang it and I am sure the passengers would not be very happy inside! Fellow club members have been very impressed and the sound is great. I have pasted some photos on our club web site in the reviews section
www.hornetsmfc.co.uk. Motors are side mounted.
Steerable noseleg was replaced with a fixed 6swg home made one as it was useless on our grass patch otherwise I was very impressed with the quality and build. It goes together really well and the instructions are not too bad - not up to Hangar 9 standard but far better than the Flair Mosquito I am building. I used all the supplied hardware which seems well up to the job. I particularly like the glass nacelle halves which enclose the engine, tank etc and the servo for each elevator half. All up weight is 11 lbs and the handling is excellent with no nasty surprises. Last Sunday I had to stop flying as I put half a gallon through it and ran out of fuel!
I would recommend you take a close look at this twin as the box is a little unrepresentative of the quality of the model in my opinion.
Guy Glover
United Kingdom
