RCU Forums - View Single Post - Servo Pecking Order???
Old 12-20-2005 | 06:09 AM
Baroncowboy's Avatar
Baroncowboy
Default Servo Pecking Order???
Hello everyone,
This is pretty random,but I was wondering what you guys feel is servo pecking order?...
For example,say I need (4) servos for a standard "all around" plane,as in one for aileron,elevator,rudder,and throttle....
Now say none of the (4) servos are equall in torque,only equall in speed...servo#1 being the strongest,and servo#4 being the weakest...
How would you guys prioritise which servo drives what???
Im figureing throttle will get the lowest torque setup,so thats already answered,but how about the other three...
After you have an opinion about that question,this time figure in that the aileron channel can have two seperate servos,one each driving its own aileron... How would you order the power priority with this set-up... What Im getting at,is I have this problem with a plane Im putting together...
Each of my servos,meet the minumum torque requirements,but each has different torque rating,and I have to buy a servo to match one of the 4 I have now,since the plane requires two aileron servos... Now,which should I match and buy to make the aileron pair... Should I buy another one of the weaker ones I already have since there will be two,or do you guys recomend matching a stronger servo on the Ailerons... Any help would be much appreciated.... Josh L.
