RCU Forums - View Single Post - How do i setup ignition/switch on Da100?
Old 12-20-2005 | 09:53 AM
DENNIS C's Avatar
DENNIS C
My Feedback: (99)
Default RE: How do i setup ignition/switch on Da100?
Ill try to explaine this the best i can without a drawing.
You have 2 leads on your switch. the lead with the bigger square end goes to the battery. the other standard end goes to the ign. its pretty simple.
just lay it out on the table before you install it.
hope this helps
i can post a picture of a set up i have laying around if this helps
