SuperCap CG Problem
I completed the SuperCap with the following config:
1. Hacker A20-20L with X20 speed controller
2. Apogee 11.1v 2100mah battery
3. APC 10x 4.7 prop
4. 1 3/4" spiner
Mounted the battery all the way upfront the fuse. Accoording to the manual the CG is supposed to be at 3" from LE of the wings. I am very, very tail heavy. I am sure I can put lead weights but seems like that is going to be quite a bit.
Anyone build these SuperCap and how did you solve this problem??
ANy help would be appreciated.
Kris
