RCU Forums - View Single Post - Plane climbs on right turn.
Old 12-20-2005 | 09:39 PM
BMatthews's Avatar
BMatthews
Default RE: Plane climbs on right turn.
I'd start by putting the upper ailerons down to flat. If the picture is any idication you've added a LOT of negative incidence to the upper wing by using that much aileron offset.
How much left thrust does it have? It would need to be a whopping great amount to cause suce a problem. I'm sure there's something else amiss here that is not really aerodynamically related.
