RE: Insight build...another wood roach.
Jarvis,
i was curious how your balancing turned out. Did you mount the wing tube per plans or adjust it. What motor are you running? Lots more questions really, but maybe easier if you could go through your experience a little. Mark is the only other person who has framed one up except for you, and me at my stage right now. weight?
As for my plane... i have been sanding, capping some more.. cut the pipe tunnel and started sheeting it. I will finish the front end once the tunnel is done.
I have ben debating and debating color schemes... just can't be sure what will look good, and what can be seen. Sigh, i prolly go with what looks good and ope it can be sen.
Anyhow.. enough rambling tonight... more sanding to do
Chuck
