RE: Genesis LE Bashing
You can't really tell from the pictures but there is a hole for the exhaust. I tested it today and it worked great. It kept probably 95% of the mud from getting inside, electronics were completely dry and nothing melted, even the engine got plenty of air. So I was having a blast in the mud, or should I say liquid dirt, making big rooster tails and driving around every where. Then the truck stopped and it reved high. Later on inspection I found a e clip missing on the front axle. I thought that was all that was wrong but upon further investigation the problem was much worse. I had to take almost the whole truck apart to get the transmission out to look inside it. When I did get it open there was a chunk of metal loose. It was the reverse gear and the reverse actuator. I have no Idea how this could break because I made sure I was completely stopped before ever hitting the reverse button. I hope Cen will replace it because that should not break that easily for no reason. Looks like no Genny bashing on Christmas[&o]
Heres some pics of it in camouflage
