RCU Forums - View Single Post - Glow Plug Recommendation
Old 11-16-2002 | 05:32 PM
ctdahle
Default Glow Plug Recommendation
I've run about 15 gallons through my .46 FX and it has done just fine on a standard Fox long plug...that is to say that it is still using the Fox standard long plug I put in when it was new.
The 46 fx, like most new engines doesn't need an idle bar.
My experience with fox plugs is that they rarely burn out unless you over drive them by turning up the amps on your power panel.
