Glow Plug Recommendation
Another aspect of the heat range and how it affects engines is ignition timing (speaking glow engines here). As plugs are changed from cold to hot, this effectively advances the ignition timing ("lead") which will give the noted increase in RPM and sometimes, power. Of course this can have a detrimental effect if you have an engine that's tuned to the edge of destruction (lean) to start with......
Sam
