Originally posted by aerografixs
I have just re-read the instructions, and your right, this part has changed somewhat, but with a twist.
If you use 100:1 Injector oil to be used in a non injector environment, then you mix it at 50:1
If you use 100:1 non injector oil then you mix it at 100:1
Sorry Dino about misleading you.
no problem glad to see all the input found that the honda oil works good also
