RE: Plane climbs on right turn.
Thanks guys for all the suggestions, I will definately keep them in mind when trying again after XMAS.... darock, the rons are both deflected the same distance up, maybe the pick was taken with the plane off, when I fly it again I will take a pic of the flight setup closer by, before and after pictures of the rons.... I am going to make them flat with the wing and remove all incidence..
About using the rudder like Herb suggested, I wish I could, I have almost thrown full rudder on this beast when turning and the tail simply will not rise.... I am going to check the CG aswell, it is sounding like a very tail heavy plane, and maybe this airframe doesn't handle that too well..... could those struts be providing enough lift for this too happen ?? well don't think so otherwise this effect would also happen on left turns....
Remember everyone, this only happens when I turn RIGHT, left turns are as gracious and wonderful as a trainer plane. I just had to keep it flying all day long with left turns when I flew it the 1st the times.
