RE: Telemaster bomb door question
Here's my Kadet Senior that will aslo have 19 LED's, no dihedral, barn door aileron's, bolt on wing's yadda yadda yadda........
This is my first attempt at the removable bombay. I want to just put on a hatch for when it's not in use. I think I need thicker ply for the doors but so far the biggest problem is the offset of the servo. It's centered when closed but the doors won't open evenly. Perhaps a linear servo dead center is the answer, you can converst a standard servo pretty cheap. If I mounted the servo at the bottom near the doors I could use a round servo arm and set it up like retracts which is another possibility.
