RCU Forums - View Single Post - What surface do you put the strongest servo on when talking about 3D planes and 3D flying
Old 12-22-2005 | 06:37 PM
AcroJo's Avatar
AcroJo
Default RE: What surface do you put the strongest servo on when talking about 3D planes and 3D flying
Now throw this into the mix. It appears that surfaces are decieving until calculated. This is on a 2 meter Extra Fun. Total aileron area is just a hair under one square foot.........each. Elevators are roughly 5/8 of a sq. ft. each and rudder is 3/4 sq. ft. So if going by area alone it would be ailerons, rudder, elevators, in order of torque required. Then as someone pointed out, shape or chord length. These particular ailerons and elevators have a 5-1/2 inch chord at the widest point, also the counter balance on the elevators is 7-1/2 at its widest point. Rudder is 8-1/2. Considering there are two each, ail and elv. compared to one rudder, I will stick with most force required for rudder with all else equal. Joe
